Hi there,
I am doing my assignment and struggling to do the last question: (only part (c))
code: Qmaple.mw
The left side shows the question. 3(d) is basically a phase portrait / vector field plot of a 2D system of differential equations on x-y plane. However,I am not sure how to extend it to 3 dimension. Moreover, for the second part, they ask me to plot x-t and y-t on the same graph,which is something similar to right hand side of the above picture (NOTE:THE plot doesn't represent the system in Question 4) . However,I've got the z term.How should I fix it?
I am working on a problem collaboratively with someone that uses mathematica, and he is getting different input for the expression i have referred to in formal notation.
I found the MmaTranslator package, and see that there is a FromMma command, but i need to convert my maple input to mathematica so that he is able to work with the same expression in an interface familair to him.
Thankyou in advance for your cooperation and assistance
Hello people in mapleprimes,
I want to know some way, if there is, to do the modification of the following, that is
The original expression: (beta*L__1/P)^beta*((1-beta)*L__1)^(1-beta)
The expression after modification: beta^beta*L__1*(1/P)^beta*(1-beta)^(1-beta)
I did this with freezing (1-beta) in (1-beta)*L__1.
But, this is a little long code. I will be glad if you tell me some more simple way to do this.
nov_21_2017_mapleprimes.mw
how to integrate this integral
g := simplify(int((s^3-5*s^2+1)/(s+2)^2, s = 0 .. x))
I have a small data sample of some occurrence in time.  For an example lets take the time it takes kids to finish their lunch to determine wether a school has given them enough time for recess.
The times are (20,15,12,18,15,13,13,10,14,14,15,17,8,22,16) in minutes.
What distribution should I use?
Should I just calculate the mean and std. dev. from the data and generate a normal distribution, like below?
with(Statistics):
a:=[20,15,12,18,15,13,13,10,14,14,15,17,8,22,16]:
m:=Mean(a):
d:=StandardDeviation(a):
X:=RandomVariable(Normal(m,d)):
Sample(X,3) # generate a few samples
I could also randomly choose from the observed 15 data points.
combinat[randcomb](a,3) # randomly pick 3 of data points
Which method would be better?  Is randcomb following any kind of distribution?
Hi there,
I've been asked to do the following and now I'm struggling to do part (c) (Part (a) and (b) are irrelevant!)
code for part(c): Qmaple.mw
So I want to animate the system of differential equations when a=1,and b as the parameter varying from 0.5 to 3,also 0<=x<=5,0<=y<=5;while t could be any arbitrary range from 0 to,say,50.However, I am not sure where to include b in my code.
Good day everyone,
I am having challenges copying equations from Maple 2016 to word. Anyone with useful information should share please.
Thank you in anticipation for your kind gesture
Hi there,
I was asked to solve this problem:
and ending up with this:
Qmaple.mw
In Solut,if I replace evalf by solve I get a sensible solution.However,it is explicitly written in the question that I should use evalf to get an exact answer.How should I modify my code?
The link below is to a worksheet giving the output of the sinc(0).  There is some contradictory results.  I know sinc(x)=sin(x)/x.  If x is very small then sinc(x)-->1.0 for either +-x.  However, for x = 0 is the function actually undefined or = 0 or = 1.0?  Check the link.  If you have an explanation I would like to be enlightened.
sinc(0).mw
I am trying to plot what seems like a simple particle trajectory along the y-axis. How would I plot a function that is just moving in a constant line along the y-axis in 3d?
Dear all!
Hope everyone is fine with everything! I want to simplify the following expression
diff(u(y, t), t) = (A^2/nu)^(1/3)*nu*(diff(u(y, t), y, y))/(A/nu^2)^(2/3)-(A^2/nu)^(1/3)*sigma*B^2*u(y, t)/rho+(A^2/nu)^(1/3)*g*beta*q2[w]*sqrt(nu^2/A)*T(y, t)/((nu*A)^(1/3)*k)+(A^2/nu)^(1/3)*g*beta*T[infinity]/(nu*A)^(1/3)-(A^2/nu)^(1/3)*g*beta*V[infinity]/(nu*A)^(1/3)+(A^2/nu)^(1/3)*g*beta1*C(y, t)/(nu*A)^(1/3)-(A^2/nu)^(1/3)*g*beta1*C[infinity]/(nu*A)^(1/3)
I above the red terms need to simplify i.e., we can add the power of A, nu etc. But maple can't do that please fix my problem. For more detail I attach my maple file.
simplify.mw
I am trying to plot matrix in maple, and from the help i believe i need to use matrix plot.
I am trying to do something like;
matrixplot(Matrix(2,2,{x^2,y^2,x*y,y},[x,y]);
for example. Is there a way to do this? Just like plotting a graph without specifying the range of x and y.
In the uploaded worksheet, using "solve" takes too long to evaluate and won't answer, while "fsolve" will only simply rewrite the equation. What am I missing?
 1-parasitic.mw
Dearz!!!
Hope you all are fine. I am stuck to find the integration in the attachment. Please see that put your valuable suggestion to fix my problem. Thanks in advance
Dear all!
Hope everything going fine. I want to transfrom the derivative diff(u, y) into diff(U, Y) as disscussed in attached file. Please see the attachment and fix the problem. Thanks in advance
Transform.mw
First 902 903 904 905 906 907 908 Last Page 904 of 2427
